cut clutch line.
Rb7604@gmail.com's avatar
cut clutch line.
Bigrick31's avatar
Bigrick31
so i was cutting out my firewall tubs to make them a little bigger and got a little happy with the grinder and ended up cutting my clutch line. the hard line thats in there now had to be hand bent and was a bit of a pain to install. just wondering if i can just cut out the damaged section and replace it with a soft line with clamps on the end to couplethe hard line back together. or does it all have to be hardline?
tbmx86
Your clutch isn't that low of a pressure, so I would imagine youd be better off to do the safe way better than having your shit blow out going down the freeway. If youve already got it apart just go ahead and fix it right. Do all hardline.
TwistedMinis's avatar
TwistedMinis
Lol, I remember when you did that.
xmdragonass's avatar
xmdragonass
DEFINITELY gonna want to replace the whole line... sorry i know it sux to hear, but its gotta be done... next time try to be a little more careful.... its ok, we all have done it at least once before, i know i have !
tbmx86
Me? I never did that. But its something that I would probably do if the oppurtunity came around. Haha. I cut mine when I took my cab off though, but Im puttin an auto tranny back in so f it.
Bigrick31's avatar
Bigrick31
alright looks like ill be taking a trip to buy some hardline for it soon then. anyone know if theres a tool you can get to bend that stuff so it dosnt kink on me?
cookiemonster13's avatar
cookiemonster13
yeah there is a line bending tool. you can buy a cheap on for around $10.
low_pup
i used a small pressure fitting to repair a fubbed breakline from my cab. i just cut it compleatly apart then pit it in the center and tightend it down on both sides nice and good. worked like a charm, may work for ya. just throwing it out there.
nvrdunizu's avatar
nvrdunizu
when i worked at a shop in vegas this guy ron that i worked with seemed to love cutting brake and clutch lines. i remember this toyota that we were bagging he must have cut like 10 different line. anyway you can usally go to you local house of hose or ace hardware like place and they brake and clutch lines that have a spring wrapped around them so that you cand bend them with out kinking the line , they come in all diferent lenghts and sizes. hope that helps
Bigrick31's avatar
Bigrick31
shit yea if i cna just cut out the section and use a compressions type coupling on the line that would be kick ass as well. if not that spring wraped line sounds like pretty awesome shit.
