New Brake Lines With Bags
thatsmydawg2022@yahoo.com's avatar
thatsmydawg's avatar
thatsmydawg
what do all you guys do once you bag your truck how do you go about runing you rbrake lines for the back if you do a lever set up with alot of lift so you use a flex line or stainless or something and the front with the turning and stuff how do you redo the lines? and how do you attach it to the frame either zip ties or bolt it to the frame with soem clamp mounts?
TwistedMinis's avatar
TwistedMinis
I got stainless lines for a 4" lift to set it up in the back. I also used the stock line holder, just moved it onto the notch.
thatsmydawg
well i got a frame built so ill have to weld new brackets or something on
TwistedMinis
So get some brake line clips. I'm ust saying, I moved the stock line holder because it bolts on.
thatsmydawg
and use some flex stainless line for the back? since its only one line for the back of the dawg
thatsmydawg
and can you get a roll from napa i know they used to sell them but then they didnt make them anymore so do you all just use pieced up likes with compression fittings?
