s-10 HELP
dailydragger00@yahoo.com's avatar
s-10 HELP
riceeter85's avatar
riceeter85
i have a 2000 s-10 amd iam relocating my tank into the bed i have to bring up a return and supply line. what is the best type of hose to use to extend the lines any help would be great i have a show this weekend that ian trying to go to thanks mike...
incognito 1's avatar
incognito 1
take sample pieces of ur old line bring it to the parts store and match it with new rubber gasline make sure to tell them it is for gas line. "???"
bdydrpdblazr
save yourself some trouble and get yourself a fuel cell. plus it will look tons better than the orginal gas tank in the bed.
riceeter85's avatar
riceeter85
iam planning on doing a fuel cell but i cant get one in time for the show iam going to so i have to do a stock for now its a brand new tank anyways so it looks half way good...
riceeter85's avatar
riceeter85
anyone know what the pressure rating is on normal gas hose
solows10's avatar
solows10
idk but you r truck runs at roughly 17psi if it was the vorteck in it
91 drggn dime's avatar
91 drggn dime
the vortec CPI motor runs 55-60 i believe.. i think the vortec TBI is in the 40's somewhere...
CryingJoker
either way if u go rubber line just go in and tell em u need fuel injection gas line, it's high pressure and can take the pressure that ur engine makes either way, that'll get you by till you can get ur fuel cell
mrbjk1
Most EFI motors are 45+ psi
lownoma99's avatar
lownoma99
yea... u need fuel injection gas line. do not make the mistake of getting regular fuel line from the parts store cuz it is only rated to 15 or so PSI. ur motor should run at around 45-50 PSI. also, to do it right, ur gonna want fuel injection fittings to clamp everything on with, not just regular hose clamps. just so u know, these fittings and line are expensive. We found steel braid at a performance shop n those fittings to be about the same price if not cheaper, so u might try that first
