Mounting computer and ABS 97 fullsize
Laser2998@yahoo.com's avatar
Chevyguy's avatar
Chevyguy
Where are most people mounting their stock computers and ABS controls when you remove the inner fenders? Just took the front off my truck last night with the help from some club members and now have to come up with a way to make some brackets to mount everything. Where should I start?
riceeter85's avatar
riceeter85
i have a 2000 s-10 and my computer was on a bracket that i made out of flat bar it was three sided and bolted to my inner strucure of my fender high as it could go. now i have it under my dash. with the abs i took mine out and replaced it with a combinaion.
mindlissmetalfab's avatar
mindlissmetalfab
On the one we did at the shop, we maintaned the front pieces of the inner fenders, Made a bracket off of that to hold the ABS, and then lengthened the wires for the computer and moved it closer to the rad cradle
bdydrp18's avatar
bdydrp18
just make a mount to hold the ABS and put the computer under the dash. the ABS you need unless you want to redo some of the brake lines . putting the computer under the dash will clean up your engine bay.
Chevyguy's avatar
Chevyguy
I like the idea of putting the computer under the dash. I'll probably try that.
bdydrp18's avatar
bdydrp18
just make sure that if you have to extend any wires that you only do one at a time. make it a lot easier
Chevyguy's avatar
Chevyguy
I don't believe I'll have to extend any wires because the harness goes from the computer to the firewall.
