92 s10 bag??
b.whitley74@yahoo.com's avatar
92 s10 bag??
JLCHEVY_VC's avatar
JLCHEVY_VC
new project about to start with 92 s10 and want to know what all have to change in front to lay out with 22's. i have seen the control arms from suicide doors that say they will lay with 22 but is there anything else that has to be done
balcar's avatar
balcar
frame notched for steering...
91 drggn dime's avatar
91 drggn dime
spindles, the right sized bag cups, a-arms, tub firewall, remove inner wells, remove heater box, move wiring on drivers side at firewall, move clutch slave if its a 5 speed, notch frame for tie rods. if you have the 'big booster', s10's came with 2.. 1 is an 11" and the other is a 9".. 9" clears 20's, not sure on 22's.
4uh8rs's avatar
4uh8rs
I LAY ROCKER ON 22S HIT ME UP IF U NEED ANY HELP
JLCHEVY_VC's avatar
JLCHEVY_VC
ok, im just going to run 20's.probably a forte f15 miami wheel. 20 x 8.5, what size tire would be best for s10? sorry for so many ??? but this is first small truck i have had to work with
