Ok..... RUSS-D Where you at??? I need you on this one!!
SMURF avatar
SMURF
Do you happen to know the part numbers for the carb and headers to get rid of all of the emissions BS???
Weber/Edelbrock Carb??
Pacesetter Header??
Thanks much appreciated.
dragginmazda86 avatar
dragginmazda86
i'm not trying to take the guru's place lol but this is what i used on my mazda weber carb kit # WK675 and pacesetter header part # 70-1140. hope this helps you out. i got both off ebay also.
SMURF avatar
SMURF
I can not find one for a 1992 B2200 online!!!! help me out!
tomkat avatar
tomkat
The carburetor you need is a Redline RGM and it's $390 from www.redlineweber.com last time I checked.
Pacesetter makes a header but so does someone else for around $220; can't remember that company's name but pacesetters are usually decent quality...
dssur avatar
dssur
The redline carb is the 38 dges, its a little overkill for a stock motor.
You would probably be happier and get better mileage with the 32/36 DGEV. It is the same carb as used on a old Volvo, or an old BMW. The difference is the mounting kit.
Some people use the Holley 5200 because you can get it from Autozone for 150 bucks or less and it will still use the weber mounting kit. You WILL need to fabricate linkage for this carb though, it is a pretty exact copy of the DFEV which is a mirror image of the DGEV. There is a writeup on mazdatruckin.com on how to make the linkage and tune this carb.
The header, only one comapny makes one, PAcesetter, and they dont list 92 mazdas as fitting because there are different emissions requirements for that year. It still fits, it even fits automatics even though they say it doesnt.
If you get a pacesetter, GET A CERAMIC COATED one. It costs about 100 dollars more, but it will never corrode, the thin wall of the header piipes will rust out in no time and you'll need a new one. Ebay is the cheapest right now, just look for b2200 header (there is an exhaust part called the header, dont buy that by mistake, make sure it says pacesetter). Nopi used to be cheaper, but I checked a week ago and they have raised their price.
