steering question
13 following
steering question
bodydropped85 avatar
bodydropped85
Edited: 10/24/2006 6:34:36 PM by bagged85
ok so im setting up the steering in teh jeep(half s10 half toyota for the RHD) and should the tie rods be level at ride height? right now the inside tie rod is 1 in lower than the outer tie rod. im just curious how much that would affect bump steer
btw its an s10 frame w/ all s10 steering BUT toyota gear mounted on passenger side.
lowdyme avatar
lowdyme
they should be level at ride height
bodydropped85
Originally posted by prymertyme
parallel with the lower arms james
hmm what nermal says sounds more correct...
bodydropped85
BaggedIndy avatar
BaggedIndy
They should be parallel with your lower controls arms, which should be parallel with the ground.
bodydropped85
kool thx guys!
BioMax avatar
BioMax
No!
You guys are answering a geometricaly specific question with a generalized answer.
Give me your e-mail and I will send you a front suspension article, with pictures, that will explain how to "set up" tie-rods.
unusualfabrication avatar
unusualfabrication
Max, can you send that article to me as well, my e-mail is draggnrockers90@aol.com
bodydropped85
kool, pm sent! thx max!
