Chevy Avalanche Set Ups
Roulette avatar
Roulette
Hey party people...
Does anyone have any pics of an Chevy Avalanche speaker set up?
Box under rear seat? Amps under rear seat?Box ported through the bead?
NisAznMonk avatar
NisAznMonk
Check out www.innovativerides.com and look for thier Escalade EXT setup.
Roulette avatar
Roulette
Good lookin out, thanks!
fatheadjames avatar
fatheadjames
JL makes a box that replaces the midgate behind the seat. Kinda pricey but it is a custom fiberglass box. I've installed a few and they aren't bad.
Roulette avatar
Roulette
That I may want to look into, as of right now I have a box that came out of a Suburan sitting in the bed...
JL huh? I'll have to check that out...
Roulette avatar
Roulette
Check it out, now that's a nice set up. I read though that some of them don't line up correctly. With the couple you've done, did you run into this problem?
fatheadjames avatar
fatheadjames
The first one I did run into a problem with fitment. JL auctally put production on hold till they got the problem solved. I spent a few hours on the phone with the guy who designed the box. Changes were made and the ones I've done since then have been fine. It's like anything though you have slight diferences from the factory in the truck and with the box.
Roulette avatar
Roulette
Oh of coarse...
Good to know though, thanks again for the input.
thunderbird avatar
thunderbird
very similar right? the builder is out of Sac.
http://www.stevemeadedesigns.com/gallery/thumbnails.php?album=10
jdldeereboy03 avatar
jdldeereboy03
At the shop i work at we've actully done a couple of setup's with 12's a 15's thru the midgate and building a fake wall to replace the midgate.. havn't had any problems with leaking or anything...
