help! truck is airing up on its own!!?
13 following
pmpm06
does anyone know what would be causing this? i'll lay the truck out at night, and by the time i wake up the next morning, it's aired all of the way back up and the compressor may kick on a time or two automatically while it sits through the night...thanks!
complexdesigns's avatar
complexdesigns
How are your compressors wired? You might want to try wiring them in to turn on with the key. Also you probably have a stuck valve, take them apart and clean them. It could also be the wiring if you have them hard wired in possibly?
LndRanger86's avatar
LndRanger86
MY GUESS WOULD BE TO CHECK THE VALVE'S FOR ANY LEAKS.THE FILL VALVE COULD BE SEEPING AIR PAST.IF NOT THAT CHECK FOR A SWITCH SHORTING OUT.
huisurdady's avatar
huisurdady
sounds like ur fill valves are leaking. is all of em leaking?? might have em on backwards.
TEEBAGGINNN's avatar
TEEBAGGINNN
Put a switch on the compressor or wire the power to come on with the ignition.
Take all of your valves apart and clean them.
mtm's avatar
mtm
dssur's avatar
dssur
HAHA now there is a car that was alive. The special effects in that movie were awesome, and he did them before there was really any computer animation...
h2omelon(nick)'s avatar
h2omelon(nick)
laidout94toy's avatar
laidout94toy
upleak, its a valve leak!
pmpm06
thanks guys! i'll clean the valves and see if that fixes the problem!
