relocated gas filler, tube
pbarone_iv@hotmail.com's avatar
Dejavu's avatar
Dejavu
i relocated the gas filler to beind the license plate in the combo on my borhters truck. i want to know what i can use to go from one metal tube to the gas tank? can i use a radiator hose? will the gas react with the rubber in certain tubes and contaminate the gas?what should i use?
mindlissmetalfab's avatar
mindlissmetalfab
rad hose will break down. not sure what you can use or where to get it, but if you find out, let me know too. haha.
keele's avatar
keele
Yes over time radiator hose will break down but it is really your only option that I know of other than Stainless Steel Pipe and you would have to have a bender to bend it if needed. Radiator hose is what they send you when your order a body lift for a truck and need to exstend the filler neck alittle. Just my 2cents
dragrocker
dont use radiator hose, it will break down and fuckyour injectors up. i went to napa and bought a straight 4' piece of gas hose. should be able to get it at good parts stores.
dirtyd97
there are alot of car at the wreckers with long gas hoses you can make one of those work or get a muffler shop to bend you up a pipe the fits between the tank and fill pipe and just cut off old gas line to link them together with some clamps...
bdroppeddak's avatar
bdroppeddak
everyone says it breaks down, but gas just flows over it, it doesnt hold gas for an extended period of time, how long would it take with gas just running down it a couple times a month? i used it on my old mazda and didnt have any problems, i only had it done about 7 months though.....
lownism0
couldn't you bend up a piece of exhaust pipe to connect the two.
jumbo's avatar
jumbo
i used rad hose, no problems.
