after you pull trim molding off a truck, whats the best way to get the rest of the crap that held it on off?
olskoolpup
ive used a eraser wheel on a drill with good results. just gotta be carefull not to burn the paint
TuKnRaiL
Hey man when I removed the molding off of my fullsize chevy I took 3m adhesive remover (it's in a red and white can) I soaked the tape with it and then took a plaatic razor blade that was bought from lowes and it just scraped right off!!! Hope this helps
yeah, at my shop we use an eraser wheel works great, but like tuknrail said, the 3m stuff works to
lownism0
yeah I use the eraser wheels and 3m adhesive remover at the shop I work at.
blkota
i used the 3m adhesive remover it worked great it just takes some rubbin or scrapin to get the adhesive off
shitty
spray paint
balcar
shitty is on crack
bdroppeddak
Originally posted by Shitty
huff spray paint then beat it off with a hammer
great idea! i used a wire wheel since the above suggestions involved buying more tools or solvents. the truck is getting repainted, so i just lightly brushed it off witha wire wheel.
