engine driven compressor
Z
bodydroppeddually
what type of oil do you put in them? do you use compressor oil or engine oil? there are some people that run air tool oil. just want to know what to run.
libtecguy145's avatar
libtecguy145
30 weight non-detergent compressor oil is what i use.
TukinRange
same here
bodydroppeddually
bump
bodydroppeddually
bump for the day.
fatheadjames's avatar
fatheadjames
30wt non detergent
91 drggn dime's avatar
91 drggn dime
i use 30 weight non-detergent. 10w30 or any other conventional motor oil breaks down too fast for it, it will burn up if you dont add to it daily
bodydroppeddually
how much should i put in it?
91 drggn dime
they sell a dipstick at onboardair.com for 5 bucks.. mine is mounted on its side in the stock ac location, so i just fill it up till it comes otu the top, but it spits a lot more too for being over filled.. it sucks
nrskinny's avatar
nrskinny
I have a york 210 for an EDC. I use A/C oil, or ester oil. It seems real thin, but works fine. Not sure what type comp your running but mine takes about 8oz. Anything more than that it just blows it through the air line.
