is there anyway to bypass a clutch?
11 following
detached.org@hotmail.com's avatar
detached's avatar
detached
ok i have a 93 chevy s10, the clutch is shot im pretty sure. the clutch pedal hits the floor when pressed in and doesnt return to a upright position without being pulled back up by hand..
also anybody know how much a typical clutch replacement goes for on a s10
no1lowr's avatar
no1lowr
fatheadjames's avatar
fatheadjames
Could be just the slave cylinder gone out. That happened to my isuzu. 30 bucks and about 30 minutes later it was as good as new.
F
fuller
yeah check the slave cyl 1st, could be shot or might just need to be bled
balcar's avatar
balcar
Erik doesn't know what he is talking about, check the master cylinder first, then the slave. Don't forget to check the flexable lines also, i have had them fail also.
detached's avatar
detached
ok thanks guys ill try n check those out. reason i asked is cause later this month there is a car show thats local i wanted to attend with this ride...
c10onfire's avatar
c10onfire
Not to jack anyones thread or anything, but what about when the clutch pedal won't go down at all. I mean I could stand on that bitch and it won't move! What could that be? It's a 95ish nissan hardbody with the 4 cylinder. It's for my boy, Meeknissan.
trashed's avatar
trashed
man i had a nissan that was like that, the slave cylinder was locked up and i had to replace it. i stood on that pedal and the line EXPLODED off of the master cylinder. looked like someone set off a brake fluid pipe bomb in my garage.
kaoss's avatar
kaoss
usually on chevy's,if you put in a new cylinder and don't replace the other one, the one you didn't replace goes out also.
bodydropped85's avatar
bodydropped85
when working w/ hydrulics, its agood thing to replace them both at the same time, i e calipers/wheel cyliners also.
