square d press. switch
1twztdwagon avatar
1twztdwagon
i did not get any directions with mine an suicidedoors is closed today anyone know how to hook it up?
Low_SST avatar
Low_SST
go to their website there is a link with a diagram there. under air management i believe.
no1lowr avatar
no1lowr
maybe this will help
Low_SST avatar
Low_SST
that doesnt show the wiring for the square d, just a 2 wire ps.
slammeddime avatar
slammeddime
Check out my wiring diagrams at http://www.airridetalk.com/wiring-info/
no1lowr avatar
no1lowr
oh my bad.
91 drggn dime avatar
91 drggn dime
yeah the Square D doesnt need an external relay. i belive there is a diagram at www.bagginit.com
wht01ranger avatar
wht01ranger
if you are running any type of unit that runs at a high amperage, you need a relay. I.E. multiple compressors or a single high current draw compressor.
and that square D switch can handle a good amount of amperage. if you want to run no relay, just make sure the switch you get is rated for the amperage you're putting through it.
AVTekk avatar
AVTekk
all square d's come with directions, its a little folder up piece of paper inside the housing, and i think the sticker inside the cap has it too..either way, that switch has two curcuits, and you only use one for each comp. theres a plastic divider in the middle of the four terminals, you only use two terminals on each side, you dont jump across it. then just hook it up like any other p/s.
1twztdwagon avatar
1twztdwagon
http://www.airridetalk.com/images/stories/wiring/1_1_1.gif in this picture only one side is hooked up i have 2 compr. do i only need to hook them up to one side ? what if i fused the switch an just ran it straight to the batt instead of jus running it to the ign wire..
