gas tank leakin
11 following
gas tank leakin
javi
what do u guys out there use to repair ur gas tank? i got a small leak from draggin my dime
BAGD RANGER's avatar
BAGD RANGER
#### BAR OF SOAP ####
dragwithme's avatar
dragwithme
take it off and get it welded
Rambo
soap works fine
you can also use a 2 part epoxy putty and plug it that way.
TwistedPhil's avatar
TwistedPhil
I've seen soap hold for a lot longer than it seems like it should, but it should definitely be considered a TEMPORARY fix!
The totally proper way would be to weld it up or weld a patch panel in, but epoxy will be just as permanent if it's done right. Just make sure the area is clean and not still leaking fuel, or it won't bond correctly!
What type of truck is it? I have a couple of random gas tanks kicking around the shop that I might be able to let go cheap... I checked your profile, but nothing!
-Phil at FBI
bodydropped85's avatar
bodydropped85
get a fuel cell, problem solved.
fatboysS1O's avatar
fatboysS1O
hey Phil i think hes got an s10,not being a smartass at all just trying to help ya out,i say this cuz he says hes got a small leak from draggin his "dime". s10= sdime,dime,etc,etc! again not being a smartass.
MagicMikey's avatar
MagicMikey
i had the same problem so i took mine off and welded it, but i didnt wait long enough for the fumes to clear out. i did fill it with water and it still went boom. luckaly all the dents came out and i did blow my self up, loud as hell tho. if you decide to weld it clean it out and let it air out for a few days ,and not a few mins like me lol.
thatsmydawg's avatar
thatsmydawg
there is this stuff called waterweld you can use it underwater in a gas tank and it sets up to a steel like epoxy. you can sand it tap it paint it and you can use it all when its wet too.
Rambo
if its steel i would just cut off the bottom of the tank until it clears, then weld it up and get some gas tank sealer from por-15 and seal it back up and be merry.
