why cant i burn out in my truck any more
hardbody_188@yahoo.com's avatar
hardbody88's avatar
hardbody88
before i bagged my 88 hardbody i use to lay down patches in 2 gears. ever since i bagged it all it does is hop.anybody got some tips on how to stage it i.e. change four links, add wieght,put oil,get some slicks,put a v8(yeah right),f**k i don't know if you got advice hook an amatuer up. all ride!
FreelandKustomz's avatar
FreelandKustomz
its the way you got your 4 link setup i bet. your geometry is off. have you tried laying it out and doing it?
hardbody88's avatar
hardbody88
i'll try and change it and post the results thanx
BK2LIFE's avatar
BK2LIFE
axle hop is cause by shocks. if your shocks are not working correctly, like they are barely moving throught the range of lift, then your actually not gettin the benifit of having shocks. adding a 2,3 or 4 link to your truck shouldnt change anyting, as long as you have the link set up correctly. the biggest thing without seein you fab work, is most likely being caused by your shock placement
hardbody88's avatar
hardbody88
i'll try and get a picture of my rear end up on this site my shocks have alot of travel but shit i did it myself so its probably not set up right i'll post my work for everyone to laugh. thanx bro
kaoss's avatar
kaoss
lay that thing out and run it through the gears!!!
