Making hard lines.
Making hard lines.
scottshonda avatar
scottshonda
I want to make stainless steel lines to run oils, gas, air through. What are you using to make the bends in this and what are the best flairing tools out there. And where do you buy fittings and so on. Any help would be appreciated.Thank you, Scott
jeebus @ mmw avatar
jeebus @ mmw
www.swagelok.com
some of the best you can buy. every hose or line on my truck is done in this stuff.
scottshonda avatar
scottshonda
Very nice products. And nice work on your truck as well. Are you using any hard lines or are all yours braided lines and fit together with a threaded end. I have seen some lines in the past that you put a collet over the pipe then flair the pipe so it will pull the connection tight. Can you do this with stainless steel. Thanks for your info
Thank you, scott
BaggedIndy avatar
BaggedIndy
Swagelok all the way.
