Valve leaks up????
Valve leaks up????
John
I am at work and do not have time to go through all the post.I have Parker Gold valves and one of them at the rear of my truck leaks up over night. Did not do this B-4 just started, any help to get this to stop appreciated.
FreelandKustomz's avatar
FreelandKustomz
Edited: 8/26/2006 12:45:02 PM by BclassBD
you probably have a bur or water build up, take off the valve and check it out. Check for something gettin stuck, or look for water. clean it out best you can. if no luck, get a new valve
SIK_SUV
^^^^^^^^^---what he said. I had the same problem ended up getting new valves
no1lowr's avatar
no1lowr
clean ity and compressor oil your system a bit, youll never have a problem
John
Thank you all, I appreciate it.
luism1983's avatar
luism1983
i have the same problem, when i changed my bags, from firestone to slam speciaties, but if i hit it with a hammer it stops licking
AutoS10's avatar
AutoS10
same problem, get new valves.... two started leaking up almost at the same time... took them apart, cleaned them out, but they were still shot.
hardbody88's avatar
hardbody88
sorry bra could you tell me what valve leak up is?i hope i dont come across it!
lowrthnu92's avatar
lowrthnu92
when your truck is layed out , the Up valve leaks and lets air into the bag ......
iv got the same problem front and rear , but i also have a slow leak down so it doesnt lift any , in 2 or 3 days the front will have 40psi .
