Disk brake rear end?
11 following
baggedpupon22s avatar
baggedpupon22s
What rear end would I run in my 95 isuzu pickup that would give me disk brakes and posi? I know that the rodeos with the v6 have disk brakes but im not for sure if they also have posi. thanks....ryan
mmrcustoms avatar
mmrcustoms
i want to know and if i do a rodeo rear end swap will i get better highway speeds
91 drggn dime avatar
91 drggn dime
95 would make it the hombre.. which is the same as the s10.. you would want to use a blazer or jimmy, 2wd rear end that had disc brakes!
the rodeo's are 6 lug i believe.
FreakwitaFro avatar
FreakwitaFro
95 isn't an hombre. 96 was the first year.
91 drggn dime
ah, i thought 95 was the first yr.. my bad.
jetts avatar
jetts
correct
dragn168 avatar
dragn168
rodeo v-6's had the disc in the rear some troopers had the disk in the rear and some space cabs had disks in the rear if you can come across a 4x4 pup or rodeo with disk in the rear calmini makes a locker for the 12 bolt rear axle its up on www.pureisuzu.com
FreakwitaFro avatar
FreakwitaFro
i also heard that there is a std cab sorta sport pup that came with the rear disk brakes too...kinda rare though. how much wider is an amigo or a rodeo rear end than the pup?
dragn168 avatar
dragn168
they are the same size as the pups
FreakwitaFro avatar
FreakwitaFro
thats what i thought.
