Foreign Cars (honda, etc) \  accord engine swap
accord engine swap
views 144
replies 3
low mazda   +1y
my buddy is wanting to throw an H22 vtec into his f22 equipped accord. Will the motor mounts and tranny bolt patterns match? I know he will need the wire harness and CPU, but just want to know about mounting the engine..
FAUBS   +1y
Call Keith Gillespe at Hasport 602-561-8058
turboh22aakkord   +1y
ive done the swap... its pritty easy and straight forward... some say you have to modd one of the motor mounts but i never had a problem i used all stock mounts mine was a 92 accord which might make a difference as far as fitment goes... you will need to cut and re weld the power steering line to match up... you'll need to wire in the vtec (i just bought a hasport wiring harness and plugged it in.. i hate wiring)... you'll need a p13 ECU.(i might have one kicking around if you need it) and yes the tranny's are pritty much inter changable. i used all accord axles and half shafts and have had no problems. hope this helps... good luck...
rangerrudy   +1y
Go to www.cb7tuner.com they have everything you need to know about doing a h22 swap!! I just got done with mine and it was pretty straight forward!
