i have a 99 s-10 im fixing to bag which has dropped control arms, i cant use these with the bags, will a set from an older s-10 work like a 91 or 92?
booozie
Should work just fine, lowers fit from 82 to 03 S-10's.
AVTekk
ya its the same arm
BK2LIFE
why cant you use the arms? your gunna bag it, so your gunna be cutting on the frame, just modify the arms.
youll be happier in the end
olskoolpup
Originally posted by BK2LIFE
why cant you use the arms? your gunna bag it, so your gunna be cutting on the frame, just modify the arms.youll be happier in the end
dropped control arms dont mesh well when bagging. he'll probably be using drop spindles INSTEAD of using the drop arms. and since he said he IS baggin it, it would be easier to use stock arms and dropped spindles.
