I bodydropped my 00 dodge ram and not it won't get power to the ignition. half of the fuse block doesn't get power. I think i have checked just about everything. Is there anything that would make this happen that u guys have run into? i'll take any suggestions!!!!!please help...i need to go to truckbash in indy in aug....it would be nice if i could drive there!!!!!
streetsweeper1
Did you check all your main block fuses? in most cases there are fuses that you actually have to unbolt out of the actual fuse block itself just to change em. I have an 80amp fuse in my Toyota Fuse block that you have to unbolt to take out. What im saying is, there may be fuses that you may not think are fuses.
