2 tanks and 2 compressors??
bowtied avatar
bowtied
How would you wire up 2 compressors and 2 tanks? What the best way? I have to 5 gallon 4 port tanks and 2 viair 380 compressors. I am new to the airbag suspension and was needing to know how to wire all his up? How many water traps and pressure switches would i need? Where would they need to be located? I was needing to know so i could finish buying parts. I am so close to baggen my truck. But im goin fbss So whats the best way to setup my suspension? How would you do it if you started with what i got? Any help would be great. Thanks fellas. Email is low_tie_89@hotmail.com if youd rather email me direct. Please help.
LOWSILVERALDO avatar
LOWSILVERALDO
just plumb the two tanks together and have 1 pressure switch and tee the compressors together and have just 1 water trap thats how i did mine. i would put the water trap below the compressors so the water wont run back in to the compressors. just my 2 cents
bowtied avatar
bowtied
So plumb the 2 comp.'s together at a tee goin into the water trap then to the tee connected to the tanks Then run a pressure switch to a tank? Ok i think i got what your sayen thanks man.
caned96 avatar
caned96
plumb the tow tanks together two water traps power from battery with a fuse to a silinoid the out to comps with a distribution block ane fuses for both comps one pressure switch using it as an interupted ground on the silinoide and power on the silionde to a toggel switch so u can turn ur comps off when u want
