URGENT!!! Valve Wiring question
tacoboy
Hey guys, its 1:30 in the morning and were pushing to get the front bags done. We need to know what prong is positive ,negative and ground on the 3 prong setup. if anyone can link me to a wiring diagram that would be much appreciated.
dave
bendapirate's avatar
bendapirate
Did a little searching and I found this website. It has a toggle diagram. Hope it helps.
http://www.bcae1.com/switches.htm
SG
Slammed GT
We are almost done mounting the bags....need wiring schem. for the smc valves...if anybody can help it would be great.
lownoma99's avatar
lownoma99
never used SMC valves, but there was a question of this sort on here before. if i remember correctly, you dont use the middle one that sits lower compared to the other 2. dont hold me to it, but i believe thats right
BaggedMazda87's avatar
BaggedMazda87
Yeah bro, you only use the two parallel, not the middle one
And there is no [+] or [-], either pole - as long as theres a hot and a ground to each valve
lownoma99's avatar
lownoma99
Originally posted by fatman
most of the time the one on the bottom is an extra gound you need to us the ones side by side make sure you use the same ones for grounds and poss
found this quote in another post. hope it helps man. check out the discussion forum, do a search, and keyword WIRING VALVES for all topics. good luck
lilslay's avatar
lilslay
yea i jus did a post about this, tha bottom one is basically jus an extra ground, all u need is to hook up tha 2 on tha side, it doesnt matter which one is pos, or neg, jus make sure u have them tha same laterz bro, good luck
Dragthatchit's avatar
Dragthatchit
What SMC do u have? Ive never seen any without a red and black wire lead already coming out of the solenoid, red being switch, and black being ground
Hc Daytona Dragger's avatar
Hc Daytona Dragger
that makes 2 of us... bo bo SMC's?????? maybee?
1lowrado's avatar
1lowrado
probably GC valves right? atleast my 3 way valves have that setup
