what would be the best way to notch the frame for steering linkage travel without a plasma cutter? I don't have a cutting wheel, even if i did, i have a tiny ass air compressor that would'nt even spit on it. Any ideas?
Marshkid1
4.5 inch angle grinder, thats what i used to build my mini
balcar
sawzall, then grind the rest with a grinder, can pick those things up cheap at a pawn shop if you don't have them.
Pneufab
If you are careful, you can use a hole saw
t
jumbo
Sweet!! Awesome idea, pneufab!!! Preciate the help, guys.
bdroppeddak
some lowers are mounted pointing up, some lowers are mounted pointing down, with the uppers having alot less stress, whats the difference.
alienwerks03
i dont know.....i dont see a problem with it like that, its still gonna work in the same matter. and the hole saw idea is pretty cool, i never would have thought of that.
