I picked up 8 SMC 3/8" valves and 50' of 1/2" DOT line. I read up on this before buying and many folks here said - "go for it, it'll work no problem" - yet I can find no tech article or pictures of how people have done it?
Question I have is: what is the best way to get the 1/2" line into the 3/8" valve opening. Is there a fitting on the market to do this?
Please be kind in your replies...Pix are helpful, if you have em.
Thanks in advance...
kboring
Just get 3/8NPT X 1/2 line fittings....its simple
94NissanLaysDoor
if i had pix i would post them....yes they do have a fitting for this my harbody was set up like that!
im running 3/8" valves with 1/2" line on my accord.
whynotfab
Edited: 6/28/2006 11:10:08 AM by WhyNotFab
would just look like this,
with the male threaded end 3/8" NPT, and the compression end 1/2".
hit me up if you need any of those, or any other DOT approved compressions, or pipe fittings.. i'd be glad to help out.
WebCzar
Thanks guys...I knew you all would come through!Ricky - I emailed you bud.
whynotfab
hey bro, just checked my email (ricky@whynotfab.com) and didn't see anything.. if you wanna try again or even just use the PMs on here i'll check it out, and get back to ya asap. later man
SHOWTIME
yes there are many shops that offer 3/8npt to 1/2 air line brass fittings any heavy duty truck shop or semi trailer shop will have that fitting in stock or check out parker fitting any fitting company has that pc
