Compressor Wiring
Compressor Wiring
deflatd
whats the best way to wire up 2 compressors with a pressure switch thats on a toggle switch. i have 2 380s and 2 relays from viair and a viair 200 psi PS. i kno how to wire them up with the relays and all from diagrams, but whats the best way to add the toggle in the system
AVTekk's avatar
AVTekk
put the toggle on the line feeding the pressure switch, unless youre using the p/s to switch the ground, then put it on the line feeding the relays, either way you need to put it somewhere on the low amp side of the relay, doesnt realy matter where.
whynotfab's avatar
whynotfab
always a good idea to do this too, for taking time to make your system a little safer.
deflatd
hey ricky. for you on these compressors. =)
sweeden's avatar
sweeden
u takes some bubble gum and put all the power wiers togethere and drill a screw with a washer into the bed and tuck all the ground wires under the washers duhhhhh!!! Havent I taught u anything phil hahah
