help on leds
help on leds
dragbody
i ordered a pair of avs led lights and got them in and gave them to the shop and they got it all installed but they just found out that it can only do 2 functions so what do i need to order or to do to get it to do 3 functions?
dragbody
its a 94 sonoma
jetts
FBI makes a module that allows 2 function leds work as 3 function
dragbody
so if i get that tac until it convert the 2 function led to a 3 function(brake,runnning light,sigal)? Does anybody else sell them? I need next day shipping and i know FBI is not good at that. Any help would be appreciated!!!
detached's avatar
detached
avs is your awnser
chevygurly's avatar
chevygurly
I WORK AT AVS...YOU SHOULD HAVE GOTTEN 3WIRE MODULES SO YOU CAN HAVE YOUR RUNNING LIGHT,BRAKE LIGHT AND TURN SIGNAL FUNCTIONS...GIVE ME A CALL AT THE SHOP SO I CAN HELP GET THEM HOOKED UP CORRECTLY 559-486-5444
dragbody
I called last week and ordered the 3 wire modules got them in the next day and the guys at the shop that are working on my truck got them to work but they have a short some where cuz the blinkers only blink a couple times and then turn off. Anybody else had that problem before?Its a 94 sonoma
chevygurly's avatar
chevygurly
YOU MAY NEED A SIGNAL FLASH RATE ADAPTOR...SOMETIMES THE S10/SONOMAS NEED THEM...I THINK I MAY HAVE A LED FLASHER HERE..YOU JUST REPLACE THE FLASHER INSTEAD OF HOOKING UP THE SIGNAL FLASH RATE ADAPTOR
chevygurly's avatar
chevygurly
WHATS YOUR NAME SO I CAN LOOK UP YOUR ORDER
dragbody
David
