Molding rear end shut ???? Need advice.
drew.berry@wku.edu's avatar
onebadkota's avatar
onebadkota
I was thinkin bout molding the rear shut on 2000 Kota....gonna put some caddy tails in i think.....i was told that there are problems with cracking (paint) along the seems because of the flex in the bed....Has anyone had problems with this....Or should it be ok??
I
iceman9669
the bed does flex quite a bit... but you can always use supports, and if you drag hard enought you will prolly crack a body line or two...
Dragthatchit's avatar
Dragthatchit
brace the shit outta everything before u put ur skin on and u should be ok, a little overkill wont hurt anything, because the beds really flex if u ever jack ur truck up at weird angles,sooo...here the more bracing the better
