s-10 wheels offset
s-10 wheels offset
1los10
ok guys i have a fwd wheels on my s-10 witha one in spacer they are a set of 18" kmc unit so what i need to know is there offset?? i look'd all over the wheel and cant see anything about offset so does anyone know what offset it would be keep in mine i'm use'n a one inch adapter\spacer thing. any help would be appriciated
2lo4u's avatar
2lo4u
Edited: 6/10/2006 9:28:12 AM by 2lo4u
Edited: 6/10/2006 9:25:36 AM by 2lo4u
Edited: 6/10/2006 9:24:01 AM by 2lo4u
First off it won't be labeled on the wheel. You need to lay the back of the wheel on a flat surface (if your tire is mounted and sticks past the edge of the wheel this won't work). Measure from the flat surface to the mounting surface of the wheel (where it sits against the hub when mounted). This is your backspacing. You will get this measurement in inches. Offset will how far the mounting point is past center. If you have an 8" wide wheel and a 5" backspacing you have a +1" offset (25.4m.m.)
1los10
ok thanx man but does anyone know it off hand? cause i'm kinda far away from the wheels and will be a few days before i could measure them and wanted to go ahead and order a new one
