Laying out a 85 C-10
InternationalDave avatar
InternationalDave
I am about to purchase a 1985 C-10, already bagged, I'm almost positive the front frame is not Z'ed and obviously it doesn't lay body, so how do i Z the front frame, and what is the least required to get the cab on the flo! I thought i remembered reading a StreetTrucks a while back talking about just redoing the cab mounts on these trucks??? Appreciate the help!!!
Xposed1 avatar
Xposed1
Edited: 6/8/2006 7:42:49 AM by Xposed1
Just get you one of these and be done.
http://www.killerridez.com/C-10%20FRAMES.htm
There is also a link on there to the feature in Truckin.
InternationalDave
There's no need for that, these are one of the easiest trucks to lay out i just need a little help
86RED avatar
86RED
I believe a 2.5-3" Z is what is required to lay a sqare body out on the pinch molding. If you want to lay body then you will have to move your body mounts and do a little work to the bed so it will all match up. There are several threads on this subject with some detailed info. You'll just have to search for them.
InternationalDave
I'm sure there are but i searched and can't find much, if anyone would email me the info i would really appreciate it, david_denton@goldenrule.com
