Toyota 5 lug swap on Mitsu
droppedmitsu@gmail.com's avatar
droppedmitsu's avatar
droppedmitsu
Has anyone done the 5 lug swap on the front of a Mitsu. What do you need to complete the swap? Does the Toyota front rotor/hub go right onto the Mitsu spindle?
joe558's avatar
joe558
I did mine, if i remember correctly its toy hub, toy seals, the bearing are the same for both, and all the rest is stock mitsu. I had to grind down where the spindle and break alignment thing bolted together so the rotor would sit between the brake pads, you'll see what i'm talkin about if you do it. Pretty simple actually.
