damnit damnit damnit
low mazda avatar
low mazda
well, i bolted my boyds on my mazda the other daya nd it won't lay out no more. my bag is bottoming out on my top bag mount. easiest fix? my top bracket is on the upper most part of the frame. I can't move it up anymore. I know spindles would fix it, but I hate doing business with SHAIM. Would some tube lower arms help? I am only about 1/2-3/4 of an inch from laying.I am running 18s with 215-35. I already have my ball joints flipped and eveything. I need to know if lower arms would work and help me out. and if so, where should i get them from to where i can still use my stock spindles and balljoints.
katfish avatar
katfish
I don't see why not. Hey did you get the pic of that motor
mazberrydelight avatar
mazberrydelight
Z the front. 3/4" that will also bring the front frame down on the ground before the Xmember hits
lowrange83 avatar
lowrange83
control arms would work, have u already fliped ur ball joints
low mazda avatar
low mazda
naw. i am at work. can't check home mail here. but if you can, send it to brandon.blitch@robins.af.mil i can see it there.
yes i have already flipped my balljoints and that ddint help any.and i really dont wanna z the front, cuz of the bodydrop already done. that would cause me to have to go back and re-do my framehorns again.
low mazda avatar
low mazda
who makes the best arms? kustom werks or whatever? whats their web addy?
mazberrydelight
or a 1/2" balljoint spacer under the lower ball joint will give you 3/4" more drop
low mazda avatar
low mazda
where could i get a 1/2 ball joint spacer? are these safe? or would i just basically use a 1/2 plate and drill some holes on it?
low mazda avatar
low mazda
i can get 1/4 inch plate all day long at work.. could i just kind of weld21/4 inch pieces together to make a half and drill holes and that work for my spacer for the lower ball joints?
mazberrydelight
just use 1/4" and the bolts will sandwich them together
