steering on a 91 S-10 AND 20'S
JASONCRAIG79@GMAIL.COM's avatar
RA_CREW's avatar
RA_CREW
SO I MODIFYED MY CONTROL ARMS TO LAY ON 20'S NO BIG DEAL BUT NOW I'M HAVING STEERING ISUES, WILL I HAVE ISSUES IF I GO TUBULAR?
IMLOWER's avatar
IMLOWER
what kinda issues are you haveing is it tow problems
wilddime's avatar
wilddime
nope mine does fine running air ride tech, tubulars...and layin on 20's
RA_CREW's avatar
RA_CREW
THE STEERING IS HITTING THE TOP OF THE CONTROL ARM WHEN I LAY IT OUT
IMLOWER's avatar
IMLOWER
are you body dropped?
laiddime
i have tubulars and bodydropped 4.5 and i knuckled mine by the frame
RA_CREW's avatar
RA_CREW
YEAH I GOT A 3.5 BODY DROP
IMLOWER's avatar
IMLOWER
ive had the same problem with stock arms just notch the arm around the stering shaft and youll be fine just make sure you reinforce the arm afterwards
blazins10's avatar
blazins10
I HAVE A 92 WITH A 3.5 AND 20s AND MINE HITS WHEN LAYED OUT BUT IT DRIVES FINE I DRIVE IT AT 35 PSI (ABOUT 1/2 INCH ) IT KNOCKS WHEN I HIT A BUMP BUT I CANT TURN ANYWAYS AT THAT HEIGHT
