i can't get it up
rangerover_85@hotmail.com's avatar
i can't get it up
rangerover8586's avatar
rangerover8586
hey everyone i jus bought a 95 s10 and i cant get the front to lift all the way but if i jack up the front then fill the bags it lifts but if i let it down a lil and try to lift back up it wont. is it jus a case of not enoguht pressure and what pressures do u guys usually cruise with
BB
bill brasky
Yeah that is a pressure issue...what is your pressure at the tank?
Most people cruise with around 50 to 60 up front and around 20 out back
coptic120
Edited: 4/26/2006 7:54:17 PM by coptic120
I have a 94 s10 with Slam RE6's in front. My normal driving height is about 90 psi. It takes about 130 psi for full lift.
tbmx86
You cant get it up??? That sucks man. Hahaha. I run my front at 60.
rangerover8586
would it be a good idear to put a guage on the tank kuz right now all i have is one for the bags ive been rollin in the back with like 30 and the front around 80ish but thast almost all i can get in it
but today i did hook up our big ass shop compresor to it and filled it up and it lifted it but took awhile
mjavy7's avatar
mjavy7
how much preassure (to ride on) varies from truck to truk. depending in the instalation, brand of bag and distance between bag mounts. The ideal preasure is when your tires are straight with the least negative camber if possible. The rear as low as the road allows you to be.
If the truck "lifts" higher when is jacked up.....then you air supply is not sufficient to reach the high preassures required to lift the truck up. I used to carry 8 gallons at 165psi. and the did the job all day just fine.
OneDroppedDime
I had the same problem when
I bagged mine, I have to have at least, 160psi in my tank to get full lock in the front yet 130 it will lift but 160 will hop lol try more psi
jcordova's avatar
jcordova
sounded like you were having sexual problems......
Sprk Sho's avatar
Sprk Sho
Take a viagra, but don't let it get stuck in your throat! I did that once, I had a stiff neck for hours.
Twisted Galant's avatar
Twisted Galant
sounds like a personal problem.
