Extended cab s-10 frame with blazer body????
sdime20s@midsouth.rr.com's avatar
sdimeondubs's avatar
sdimeondubs
will my 01 extended cab s10 frame fit and work under a 4 door blazer body?...
any info can help... thanks...
-Micah
mindlissmetalfab's avatar
mindlissmetalfab
no. blazer frames are way different from the firewall back.
sdimeondubs
oh... damn... like the mounts?... or are they skinnier or something?... Could i use the rear axle, and driveshaft and all?...
j/w b/c now that my s10 burned up, i wanna do a blazer... but i was hopin to use sumthing off my current frame... like the SD 5 link... but if not o well haha...
could i mod it to work?... or is it pretty much a lost cause?...
thanks...
b12yan's avatar
b12yan
prolly could if u built a new floor with mounts and all
GB
Gangsta Boogie
the only similarity blazer frames have to s10 is front suspension, other than that it may as well be a totally different truck
sdimeondubs
oh ok...
thanx for all the info...
-Micah
mindlissmetalfab
yep, it'd be just as much work making that stuff all work with a blazer body, then it would to just build a stock floor frame for the blazer.
2tonesdime5's avatar
2tonesdime5
put the 5 link in the mail and ship it to me
V
vinnysmini
Yeah...like they said that the only thing that's the same is the front suspension. Blazer frames tend to curve outward near where the axle sits unlike S-10s which are straight if you were to stand at the rear of the frame and look forward. Also, the body mounts and bed mounts would be different between the S-10 and Blazer. Also, on Blazers the gas tank cross member and tank are located at the very rear of the frame unlike the S-10 where the gas tank is located right after the cab under the bed. With some modifications, you could prolly reuse the 5 link somehow. As long as it holds the rearend in place and functions.
