Where can you get a bracket liek this?
skankinandy@gmail.com's avatar
complexdesigns's avatar
complexdesigns
Edited: 4/15/2006 8:27:10 PM by complexdesigns
MRCO
i bet thats home fabbed. looks good though.
Low_SST's avatar
Low_SST
you could probably make that really easy...thats most likely what he did.
treylos's avatar
treylos
You should just make you one with a sheet metal break and some alluminum.
Stock Sucks's avatar
Stock Sucks
You really dont even need a break, you can clamp two pieces of square tubing together sandwiching the sheet metal and bend the metal over that, then use a 3rd piece of square tubing to finish the bend, this will need a little finish work to make 90 degree angle, but this will get the metal bent straight if you cant find use of a break anywhere
brad88maz
Chris and Jamie at Driveway Werx make those. Anyone know one of their SSM names?
laidmits
this is jamie's ssm name DW WERKS.
whynotfab's avatar
whynotfab
that thing's nice, way better looking than the plain ones..
brad88maz
There you go. IM Jamie^^^^^
