who makes the raised s10 tank
12 following
johnz
i believe its devious but its not on there site???
tymsrvd
devious customs, i have one they are great
LowPlainsDrifter
hey chris, how much did u pay for that gas tank from devious customs and how much smaller is it? does it work with the factory fuel pump and sending unit? thanks!
stockflooredsdime
Edited: 4/9/2006 6:17:04 PM by stockflooredsdime
It might be better to just get the crossmember that raises the tank. But it depends on how much you want to raise the tank. Check out the link.
Suicide Doors
johnz
its for my buddies s10 he already has the sd tank kit and he drug threw the tank
mazdalow's avatar
mazdalow
must not have much frame left..
droppindime00
I got the suicide doors raised cross member and it didnt raise the tank above the frame enough. It only raised it a lil bit. The devious customs cross member and tank is bad ass. It puts the tank like two inches above the frame rail and i believe it runs for 500 bucks
F
Flamedsdime
Im with everybody else with the SD crossmember. My tank is all the way aganst the cab and i still dragged a hole in it.
V
vinnysmini
I got the Devious tank and it uses the stock fuel pump/sending unit. I think it's only about a gallon smaller than my stock gas tank so it's pretty big. It comes with a new gas tank crossmember, hardware, and instructions and has a drain plug. The hardest part installing it is removing the stock stuff. It uses the stock gas tank strap and the stock rivet holes which hold the stock gas tank x-member in.
sjudd86
Edited: 4/10/2006 6:17:18 PM by sjudd86
anybody got any pictures? and does the devious crossmember work with sd 3 link?
