brake booster for bd s-10
LowPlainsDrifter
I am body dropping my 2000 s-10, I have 20x9 Rozzi Switch with a +11 offset (i think). My issue now is that I need to replace the brake booster in order to fit the tubs. I have heard of the hydroboost kit but don't want to have to spend that much unless I have too. I have heard of people using a older model s-10 booster and also people using a geo metro booster. Any help, words of wisdom or pics would help. Thanks.
V
vinnysmini
You can use a brake booster from a '83 or '84 S-10 Blazer with a 1.9L motor. It only came in those two years for the Blazer and it's GM code JM-5. It will have one vacuum line like your stock one. It will measure about 9 inches in diameter compared to your stock one which is about 11 inches in diameter. The mounting studs are all the same as the stock one and it's a direct fit.
mindlissmetalfab's avatar
mindlissmetalfab
Edited: 4/8/2006 9:02:08 AM by iLLblazer
Go to the wrecking yard and pick up a hydrobooster off an Astro Van. I paid $25 for mine. A stock 2nd gen master cylinder will fit it. All you will have to do is get some braided lines made to connect it all and have a clean setup.
LowPlainsDrifter
hey guys thanks for the help with this. i am trying to get this dang thing ready for showfest and it is one of those things that is really bothering me. thanks again!
