Powdercoating Question........Rear Axle?
13 following
tjjardas@gmail.com's avatar
jeebus @ mmw's avatar
jeebus @ mmw
yo. Im looking into powdercoating my rear axle on my newest project. My question is, do you think i will have to strip all the gears out of the pumpkin when its getting done. Or do you think its safe to bake the part with the gears all in the rear end. Im gonna pull all the braking stuff and axles off the rear axle, but would rather not have to take all the gearing and what not out of the pumpkin.
Anyone got any idea about this?
jeebus @ mmw
somebody has to have a clue?...
SHOWTIME
your gonna have to pull it apart if you don,t your axle seals and pinion seals are gonna dry out and get brittle and the frist time you run it your gonna have leaks
Dragthatchit's avatar
Dragthatchit
I agree!!
menace's avatar
menace
yeah, im pretty sure when they do powercoating they bake it at like 400 or 500 degrees, that would definately do some harm to seals and rear end grease.
baggd98dime's avatar
baggd98dime
Edited: 4/6/2006 8:57:17 PM by baggd98dime
when they are cooking it, not only will it do some harm to the seals, if there is any fluids in there left over, it will burn and start to smoke out the oven. not a pleasant smell either.so yes take it apart to have it powdercoated
dwnlowx
must be stripped completly same with the brake rotors
Uncle Fester's avatar
Uncle Fester
I had mine powder coated after it was narrowed and hot tanked. Would not recommend leaving it all together. Might take more time, but will be correct in the end.
JFcustoms
can you powdercoat over body filler?
jeebus @ mmw
thanks for the answers ppl
looks like im gonna have to start stripin it down...
