help with fuel injection
stockfloor22@hotmail.com's avatar
4uh8rs's avatar
4uh8rs
ok guys im stuck.my blkazer will crank and then it wont.wtf is the problem.i can spray starting fluid it will crank and run forever and then sometimes it just cranks.im so lost!!!!!!!!!!
bodydropped85's avatar
bodydropped85
sounds like the fuel pump. check the grounds on it. also check the fuel pressure.
4uh8rs's avatar
4uh8rs
james i cant check the pressure.so u think it is the fuel pump.do u know what the pressure is supposed to be?this is pissin me off
toffeechips's avatar
toffeechips
i would do a filter 1st to rule that out.
mooneyes1's avatar
mooneyes1
sounds like a fuel pres. problem to me as well like toff says start with the filter first then go from there
4uh8rs's avatar
4uh8rs
i havent put a filter on it yet.i just rebuilt the throttle body and put a new fuel pump in.im thinkin maybe the fuel pump is bad for the get go??????but im just lost
4uh8rs's avatar
4uh8rs
the pressure is right what next
