gas in the oil pan
gas in the oil pan
my95ondubs
traded for a new truck gas in the oil pan what the fucks the deal
madmike
what kind of truck and engine? s-10 vortechs for example are known for leaking fuel psi regulators which is located under the upper intake plenumn
thatsmydawg's avatar
thatsmydawg
maybe it was hard starting in the cold and soemone pumped the gas one too many times and gas leaked threw the rings or if it is in a s-10 with the 4.3 the injectors in those are messed up to begin with
baggedwagon69's avatar
baggedwagon69
older chevys as in mec fuel pumps some times when they go bad they still work just leak gas in to the motor
thatsmydawg
ya if its a mech fuel pump mounted on the head the diaphram leaks and runs into the oil
MRCO
aside from mechanically damaged it can just be running way rich. the CPI vortecs leak at the regulator. (says VORTEC in orange on the plenum cover)
what kinda truck/motor are you dealing with?
my95ondubs
its a 2.2 4 cyl. in a 96 s-10 but when i drained the oil pan it was just really brown like lake water and reallt thin but when i moved the pan it was like a milky color if that means anything
booozie
Are you sure it's gas and not coolant? 2.2's are notorious for head gasket leaks.
Pp_Laynbody
Sure it's not coolant?
time1's avatar
time1
gas doesnt turn oil a milky color. you got coolant in there.
