Viair problem
skankinandy@gmail.com's avatar
Viair problem
complexdesigns's avatar
complexdesigns
Just reworked my suspension and my compressors arent working like they used to, could it be a grounding issue or is it something else? Also where can you get new check valves, both of mine are broken.
whynotfab's avatar
whynotfab
Definitely check the grounds, and all connections really. Also, check the pressure switch (if using one) and relay/solenoid. Pretty much just check over everything, also I'd usually hook it direct to a battery to see if it sounds/pumps like normal that way.
For the check valves, you pretty much are better off to just order new Viair Leader Hoses.. with the swivel and built in check valve. If you need some of those hit me up, I sell them in 1/4" and 3/8"
