i just bagged my 2000 s-10 and it has lower and upper tubuler a arms i stop when my inners hit it has more to go i want to remove me inners what do i do woth all the sh*t on them its a 4.3 vortec so that computer,fuse relay,and all that has to be moved were do i put everything
V
vinnysmini
On the driver side, I took out my windshield washer tank. I made a custom mount for the ABS unit using a piece of tubing that I bent off the side of the frame to a plate which bolted to the ABS unit. On the passanger side I got a battery tray for my battery and mounted it up higher as close to the hood as I could make it. I got a smaller billet overflow tank and located it next to the radiator instead of the big stock one. We then made a bracket that bolted up to the fender which held the computer above the tire. Some people also just relocate the computer to the inside of the dash and extend all the wires on the harnesses. I also have a 4.3L Vortec V6 in my S-10. Hope that helps.
