Pics of front setup on 61-64 Impala
dooredZoo
Can anyone post some pics of the front setup on a early 60's model impala, belair, or biscayne. I'm tryin to figure out what, if anything I have to cut out of the frame for the control arms to clear and lay out on 19's without drop spindles. If I run drop spindles, will it lay out without having to chop the frame up?
Thanks.
hang time mazda's avatar
hang time mazda
you shouldnt need very much modification to lay frame with the 19's. most impalas with 13's and 14's can lay frame real easy. the overall height of the 19" tires shouldnt be much taller than the tallest 14" tire that would be used on an impala. so IF any modifications are needed, it should be very minimal. hope that helps you some.
dooredZoo
So should the front lay out with just S10 cups and little Z-ing(I call it Z-ing, prolly called somethin else) of the frame? Is anyone running Firestone 2600's up front on an S10 and Suicide doors bag cups, if so, how do you like it?
bodydropped85's avatar
bodydropped85
u shouldnt need to Z the frame. only notch it in the rear for the drive shaft. air ride makes bolt on shit but it prob doesnt let it lay i dont think
