webber help
webber help
4x4metal avatar
4x4metal
can someone post a pic of the back side of the carb so i can see where the little spring goes and show me a pic of what main vaccume line goes to the carb.....or fuckit just any pics of the carb would be nice
wormy94 avatar
wormy94
Im not even using that little spring on mine anymore it kept coming loose so I finally just took it off and it still works great
dssur avatar
dssur
yeah it makes the throttle a little soft without the return spring, but I ran mine forvever like that.
lukeinva avatar
lukeinva
I ran mine that way also. I just put the spring on the other day. Look at where you attached your throttle cable there is a little hole in it. Attach the spring there. Then that little metal piece with the 2 holes. Take out the bolt in the egr that is closest to the back of the carb. Attach the metal thing there then attach the spring to the little hole on top. Then bam your spring is attached.
lukeinva avatar
lukeinva
Check out www.mazdatruckin.com some people put up pics over there just do a search on weber installs or something along those lines
Kyrasis6 avatar
Kyrasis6
Yea I have an installation page I'm expanding as well because there is a lot of stuff the weber instructions just don't go into.
