brakes??
the_etons@yahoo.com's avatar
brakes??
SoDakminis's avatar
SoDakminis
im tryin to figure out what to run for brakes....i got rotors up front and drums out back, on a 81 isuzu pup, with a 327,,can i run manual brakes?? or is there a small brake booster?? i really dont know much about brakes....anything would help thanks
slammed88cutlass's avatar
slammed88cutlass
wilwood makes several different brake master cylinders and boosters. they arent cheap, but they are the best stuff i've dealt with as far as brakes go. i think their site is wilwood.com
SoDakminis's avatar
SoDakminis
what about manual brakes?? bad idea??
baggedhb
i would do some sort of power brakes if u can fit it sumwhere...i was gonna run manual brakes cuz there is no room on my firwall for a booster. but i ended up gettin a geo metro brake booster today for 25$, its 6" diameter and i mounted it inside the cab. the back casing inside and the filler part is bolted on the other side of the firewall so its not in the way at all and u dont see the ugly booster. i have to make a whole new pedal assembly for it to work tho. but either way its better then manual brakes cuz i have 4 wheel disc.
no regrets . wa's avatar
no regrets . wa
brakes = overrated
SoDakminis's avatar
SoDakminis
thanks for the info guys.... guess i will try an find a small booster...
DawgsledMazda's avatar
DawgsledMazda
get yourself some Trooper or Rodeo rear discs and run 4 wheel discs.
I have the Geo Metro booster on mine with 4 wheel discs and a V-8. it takes more pedal pressure but it stops on a dime.
