Planning stage for suspension ~ need help
orangemazdab2000 avatar
orangemazdab2000
I'm in the planing stages for my project truck. It's an '86 Mazda standard cab. I'm most of the way through the 2.5 BD. I want to run 20's. I want to get tubular A arms made. My question is, will I need to have the arms made narrower then stock, or will I be able to clear 20's with 4x4 fenders? (I'll also be running drop spindles.) Thanks for the help.
impulse avatar
impulse
Hit up Kustomwerks for your arms... they are top notch!!! I wouldn't get them anywhere else! they can make them to accept toyota or mazda spindles.
You should be fine with 20's and a 2." BD I would think... im pretty sure you'd be fine without the 4x4 fenders.
orangemazdab2000
I've heard that drop spindles kick the front wheels out a bit though. Is that of any concern? Or is that not true?
hopsing avatar
hopsing
have Kustomswerks build you some arms that will accept Toyota spindles, and use a Toyota rear axle. You will then be able to use any front wheel drive, 5 on 4.5 wheel on your truck and tuck with no problem.
92LOWYOTA avatar
92LOWYOTA
deff go with Kw for the control arms, bad ass quality and they are quick to get them to ya
orangemazdab2000
Can someone post up the web address and phone number for Kustomwerks? I've searched around a bit in the forums but couldn't find it. Thanks
impulse avatar
impulse
bdroppeddak avatar
bdroppeddak
are you shure he should get them now?? yours wont even lay 19s.....
