1997 Chevy Ext. Cab 1500 airbag size question?
overated avatar
overated
im thinking on bagging my truck but i don't how big i can go on front, i plan to install 22's later on, and maybe buy the drop spindle(2") I want to use Slam Bags. any help or comments are apreciated, thank you in advanced.
bdroppeddak avatar
bdroppeddak
you can go 24s bodydropped.
i have the slam re 72s up front and clear 265/35/22 with a bodydrop. best bag to put up front IMO, and i purchased them from www.gravity-werx.com
mindlissmetalfab avatar
mindlissmetalfab
yeah u can fit an re-7 up front no problem. just a little trimming of the pocket.
overated avatar
overated
dumb question, but does re-7 get 7inches of lift?
kevin@aac avatar
kevin@aac
no thats the diameter. It will get you more like 9-10 in that control arm set up.
seamoo avatar
seamoo
lift depends on of different factors
wheel/tire height
cup size
and you have to cut more than a little bit unless you like rubbing
I am using the air lift Gen 2 300 psi bags and get 11 inches of lift
BodyDragginGMC avatar
BodyDragginGMC
Edited: 2/17/2006 3:17:03 PM by LO-N-PO
It's not a fullsize but it would be even easier to put 7" bags on your truck. I love my Slam bags. They get massive lift. Here's my chassis with Slam Rs72 in all corners, ART upper and lower contorl arms, Belltech 2" spindles and a super lift 4 link. This is at 100psi. I need to get some pictures of it with the body back on. It untucks the 20/22 very good even with the body drop.
