air compessors
air compessors
X
xMariox
hey guys, just wonderin im currently have two 7 gallon tanks, so 14 total and just wonderin what would u guys recomend i should use for air compressors. i want engine driven but nows not the time for it. what would u guys say in a resonable price range that i should use to fill these tanks up.
whynotfab's avatar
whynotfab
I'd go with 2 Air Zeniths for sure.. wouldn't be dissapointed, very nice compressors
Hit me up if you end up getting those, or even Viairs.. Free Shipping, Pressure Switch and DVD of your choice.
Low_SST's avatar
Low_SST
an edc would probably be cheaper then the 2 AZ comps. i would seriously look into the edc.
no regrets . wa's avatar
no regrets . wa
i bet a az would start smoking on 14 gallons of air i did an s 1o with 18 gallons of air with an edc works kill
whynotfab's avatar
whynotfab
Yea definitely wouldnt run 1 to 14 gallons, I meant 2 lol. EDC would be bad ass if possible..
draggind21
i used a edc cause it was cheaper than buyin a good electric comp. my york owes me bout $140 with all fittings and brackets. and thats nz dollars
jmfknpizzle
im going to get az comps. so 2 az or 2 viar 450
X
xMariox
are you running the same amount of air as me dragin? cause i was thinkin maybe along the lines of 2 viars.
forbidden's avatar
forbidden
You guys should get 2 Air zeniths.. You would be very happy the way the perform. Alot faster than the Viair. The rule of thumb is 1 compressor for every 5 gals of air. You would be fine with the AZ's on 14 gal's for sure.. Let us know if you need any prices.
jmfknpizzle
i running a single five gallon for now but im going az all the way.you should too they are the best for your money
